I wondering if anyone has seen this before.
I have a Denon 2900 Modified from MSB with SDI. I also have a HD Leeza feeding a Infocus 777 with DVI. I think I have the Scaler set up properly @ [email protected]
With the DVD hooked up this way the picture is offset vertically too high. I have tried to use the "R2" function to manually push the picture back down, but I can't move it far enough. Not only that, but the picture looks really lousy. There is artifacts and jumpy lines on anything that is small and panning on the screen.
I have tried hooking it up with component with success. So I'm pretty sure the DVD player is fine. I have also tried reversing the polarity on the scaler.
I'm concerned that the MSB mod is not compatible with the Leeza. I called them before I purchased to confirm that it should work. But there is other companies, like PMSvideo, that ask specifically if you are using a Leeza. Why is that?
I called Key Digital and MSB on this. No one could give me and answer on this, I'm hoping someone here can.
Lance
Lance
