Status
Not open for further replies.
1 - 3 of 3 Posts
When the unit is in reg mode I get like a flashing on all channels, by flashing I mean the picture will flicker for a while like the sat connection was loose or something, It is not picksation. If I switch to high definition, the picture is great on all channels.
Checked all connections and they are ok and signal strngth is in 90's
Any Ideas ????
Premium Member
It could be a bad cable. Since the SD output is available on S-Video, composite and RF, you could try each output type. If it happens on all 3, the problem would be the receiver.
1 - 3 of 3 Posts
Status
