Problem with IMON VFD
462 Views 2 Replies 2 Participants Last post by  jedwards
Setting up an HTPC using the Lascala LC10 M case, I am having a problem getting the Graphic EQ function to work on the VFD. I set the VFD software to use the correct port (realtek HD Audio rear output), but the Display reads "Graphic EQ mode" and does not actually display the EQ.
I am running the latest version of the IMON software on an intel 925X MB.
Any ideas would be appreciated.
Status
Not open for further replies.
1 - 3 of 3 Posts
Are you using S/PDIF? If so make sure that that box is checked along with no others.
No SDPIF yet - just analog out for now to computer speakers while building. I will eventually be using via SPDIF at home.
1 - 3 of 3 Posts
Status
