1 - 3 of 3 Posts
I built renethx's J&W MINIX 780G-SP128MB $361 build. I got it altogether. On start up it beeps once ,no post, just goes to flashing curser. I reset the the bios with the jumper, beep twice i think, it then started up into bios. So i thought battery, battery checks OK at 3 v. any help. I just got it from Amazon should i RMA it? This is my 4th PC build so i am not a complete noob, but close. Also thank you renethx ! Sorry about the repost.
Hi there I've have this motherboard, and I experience a similar problem.
Everything powered up but no pictue or text.
I got just 1 x 1GB of ram and had it in ram slot Positon 2 which i think is the slot furthest away from the processor.
I placed the 1gb of ram in the 1st ram slot and it worked fine.
See if that helps.
Discussion Starter · #3 ·
Yea, i switched the ram around, but did it not help thanks. I thought of that after wrote the post.
1 - 3 of 3 Posts
