1 - 4 of 4 Posts
Just picked up a 58vt25 last week, Whenever i switch the input from cable to let say blu-ray or xbox and i go back to cable i get no single sometimes snow or just a black screen i have to turn the TV power off and then back on and then it comes right up. Not sure if theirs something wrong with the TV or some setting i can change any suggestions
Try hooking the cablebox HDMI directly to the TV. Also, it may help to turn the TV off, unhook the cablebox and rehook it.
Also, you can see if it's a problem with the cable box or the TV - just try a different HDMI component on the same input.
Otherwise, check out the settings on your cablebox - maybe they're messed up. Go to default and then re-set everything yourself.
1 - 4 of 4 Posts
