1 - 2 of 2 Posts
Discussion Starter #1
Hello everyone! I'm posting this because a friend has recently started having issues with their 3 year old Philips 40PFL7505D/F7. The TV displays the artifacts (vertical lines) shown in the picture below. Any ideas what might be causing the problem? Could I personally fix this (at low cost) by purchasing a replacement part for a defective component? Thank you very much for any help!
Discussion Starter #2
I've been doing a bit of research and seem to run across a common solution of replacing the timing control board for vertical line artifacts. I did a quick check on prices on eBay and it seems the board can be bought for this model for under $30.  Would you say the symptoms displayed in the picture are consistent with a timing control board malfunction?
1 - 2 of 2 Posts
