Status
Not open for further replies.
1 - 4 of 4 Posts
I'm having trouble playing dvd's with my new mobo. It's a msi gnb-max, e7205 chipset. The problem is something to deal with sound, because if I disable the sound card, the dvd will play fine. If I enable it, the dvd software will crash. I have tried using the onboard sound with the mobo, and a separate pci sound card, both will cause the software to crash. I have tried pretty much all of the software dvd players. I, also, have the same problem when trying to play hd .ts files.
Any ideas on how to fix this?
Hmm. Have you up to date mobo drivers?
Did you reformat when you installed the new mobo?
You have any conflicts in your device manager?
Discussion Starter · #4 ·
Yeah, I reformatted my harddrive, and did a fresh install of windows upon installing the mobo. I also got the latest drivers.
There are also no conflicts in the device manager.
If I build a graph in graph edit to play the hd files with no sound everything works fine. But, when I throw in sound, it crash immediately.
It's very frustrating because I built this pc specificly for playback of hd files. I have emailed msi and got no response. I don't know where else to go for help.
1 - 4 of 4 Posts
Status
