Hi,
I have decided to redesign my home audio/video setup to save the hassle of constantly reconnecting wires. I ordered the parts and put it all together, in the end I need to manually re-plug the wires to switch between Mode A and Mode B.
Everything works great with Mode B, but my problem lies with Mode A and the projector.
There are constant horizontal lines that are moving upwards and the screen will go blank for 2 seconds out of every 20 seconds.
My initial guess is that the 50' cable was killing the current, so I tried a 30' cable. Unfortunately that didn't fix it.
I also tried taking Mode A and bypassing the switch, directly into the Cable Box. Again, same issue. A friend suggested that the VGA Gender Changer could be introducing a lot of static, but I figured I'd post here before ordering anything new.
Any ideas as to how I can fix this problem?
Dimava
Dimava
