Hello,
This weekend I was getting my HTPC ready to show a DVD for the first time after rebuilding it with pretty much all new components. Whenever I turned on DMA on the DVD-ROM and tried playing, the drive would just freeze. I spent a good 2 hours changing settings in Windows and BIOS with no change in the behaviour. I wound up having to bring the DVD player down from the bedroom and hook it up to the projector.
After all of that I did some more searching on MSI's site (motherboard manufacturer) and found one post regarding a problem with round IDE cables and a CD burner. I figured it was worth a shot so I switched the DVD drive off of the round cables and replaced it with a standard ribbon cable. Everything works perfectly now.
Is this a common problem with round cables? This was my first foray into using round cables so I have no other experience than this bad one. Was this just one bad set?
Thanks for any insight you can give about this.
