Hi,
i've got a problem with my Seleco SVD 800HD. There is a white vertical line within the signal on the right side. It's there with every source i use and even if there is no source connected and i use the internal testpictures. If i use the 800 with a 32 kHz PAL signal i can move the picture with phase to the left and hereby the white line moves outside the visible signal. (this is just a workaround and no good solution!) My problem is now that using the 800 (it has a maximum of 72 kHz) with about 64 kHz (linedoubled 100Hz or linequadrupled 50 Hz) the white line can not be phased out because on the left side there is not enough space to move the picture. The white line is just too bright to ignore. I know two another users of the 800 who have the same problem. (i visited one of them last weekend)
It seems there is a bug in every unit?
Has anybody an idea what this could be or has the same problem ?
Regards and Thanks, RalfS
PS: Are there any Seleco users out there ?
