Hi,
I've got an used 1271 (only 221 hours) for 500€, but I've a problem.
The CRT is connected to an HTPC (Radeon 9100 [email protected]).
When I see DVD I've noted that there are two white line at the bottom of the screen and on the left side.
These lines are not very visible and are outside the desktop area of the HTPC.
I've noted that these lines are also visible in test mode and also when I switch to other input channel.
Note : In test mode if I shut down all tubes, the lines are visible.
I haven't reset the CRT, but I think that there is an hardware problem.
Can you help me to find the problem (or what test can I do) ??
Thanks....
Thanks....
