Status
Not open for further replies.
1 - 2 of 2 Posts
Hi everyone,
I've had the Sony HD-200 for several months now. Every month or two, the unit randomly resets itself while it is on and I am watching TV. Then, it proceeds to scan the channel list again, like it did the very first time I powered it up. This gets annoying because I set up my custom channel list so that the channels I don't subscribe to on DirecTV don't show up on the channel guide. When it resets, every single DirecTV channel shows up on the guide. I've gotten tired of resetting my custom channel list every month, so I have to page through a hundred channels I don't even have to find out what's playing on the channels I do have.
Is there a fix to this problem, or is it just a faulty unit?
Sounds like you have an older HD200. This is a common problem for units manufactured before say Aug or Sep, 2002. You should check the mfg date and return the unit to the reseller. My second HD200 dated Oct, 2002 does not have this problem.
Good luck,
Al Rovner
1 - 2 of 2 Posts
Status
