Split screen you say?
Originally Posted by ogbuehi That happens all the time. When I'm playing Halo 2 with somebody I have to set the 360 back to 480p in order to get the normal split screen. |
Originally Posted by NoThru22 BTW, in widescreen, it should be split side by side. |
Originally Posted by ogbuehi Not if you lower resolution output on the XBOX or 360. That's how I eliminated that side by side splitscreen on my both my widescreen. |
Originally Posted by NoThru22 I realize you can fake it out and make your TV think it is 4:3, but if you have a widescreen TV, I think the best way to split it is side by side. If you take 16x9 and split it down the middle you have two 8x9 screens but with 4x3 if you split it top to bottom you get two 2x3 screens (which multiply by 3 and it equals 6x9.) So basically, you're actually seeing less side to side and you're stretching it out across your TV. |
Originally Posted by kylebisme Then I recomend just pulling the scaler out of the loop then so you can be wowed by how much better your 360 looks when it is acutally running in HD. |
