Status
Not open for further replies.
1 - 4 of 4 Posts
I have a motorola dct 2224 cable box and i am having trouble getting it to change channels properly.Many times it will change to the wrong channel either missing the first digit and sometimes the last.Does anyone know of a code that works best with this box with proper settings?would be appreciated
Enable Fine Tuning: Yes
Codeset: 4476 (if this doesn't work try 0476)
Send Enter: Yes
Minimum digits to send: 0 (try changing this to 3 if you have problems)
Inter-action delay: 0100 ms
Response delay: 1500 ms (increase this number if the blue screen still shows up)
Pre-command delay: 0000 ms
Inter-Command delay: 0100 ms
lizard boy..how do i get to those options on a 5040?
I'll field this one:
Under Menu-->Setup-->Network and Input settings
Navigate through the menus to enter in the IR blaster code for your particular box. Once at the list of code, press ZONES on the remote while highlighting your particular code and you will be taken to the fine tuning screen.
1 - 4 of 4 Posts
Status
