I am trying to get BH200 to recognize the PAL format.
Following the instructions below, I got to the EEPROM and reset the 4th hex value to 80. Hit pause to save, turned it off, etc.
Turn it back on, still doesn't recognize any PAL format disks. Still plays "normal" NTSC disks without issues.
Now I am unable to get back into the EEPROM menu no matter how many times I hit Pause, 1, 4, 7, 2 with the disk drive open. It just displays AT 00 on the unit and does nothing.
Worse, the "Home" menu doesn't work when I hit the Home button... I never got to it before so I am not sure if this is a new problem introduced.
I escalated this to LG. They said it's a firmware issue and they are sending me a disk with new firmware.
Once again, normal off-the-shelf DVDs play just fine, apparently at 480p. None of the PAL disks play at all.
1. Open the tray, with no disc in the tray
2. Press PAUSE, 1, 4, 7, 2
3. Change the fourth HEX value (the bold value in the defaults above) to: Region A - 80, Region B - 92, Region C - A6 - Does your TV support PAL? See Below!
4. Press PAUSE to save & close the EEPROM Menu
5. Turn the BH200 Off - Normal power button
If your TV doesn't support PAL, use these alternate codes (if you're unsure, use these codes!): Region A - 00, Region B - 20, Region C - 26
NOTE: The Region B and Region C codes will also disable/hide the "Network Update" option, switching to Region A will enable/show it again.
You will notice the code to switch the BH200 to Region A is the same code that enables PAL below.
