Encoding with WM9 has been a complete nightmare. I can never get multichannel encoding to work(5.1). I follow this guide to help in compressing my DVD's. http://www.avsforum.com/avs-vb/showt...g&pagenumber=1
I use the avisynth method and I use Bespliced to correct the errors in the ac3 5.1 audio stream; although I don't think I really need to. Anyway when ever I encode the audio stream with the video, there is no audio at all? WTF? When I try 2 channel audio encoding, it works although the audio is a bit out of sync, at least it works. Every time I select 5.1 audio encoding and the following setting "Quality 90, 48KHz, 5.1 Channel, 24-bit VBR" it never works! I get absolutely no audio at all. What am I doing wrong? I have WinDVD Platinum with 5.1 audio selected and I have a Soundblaster Audigy 2. However I don't have 5.1 speakers at home and I have Logitech z560. The multichannel audio should at least fold down to stereo anyway. Is there any chance that the ac3 audio isn't a 24-bit stream and it doesn't correspond with the setting from the encoder? It does mention 48KHz for the ac3 audio and so I thought I should select it. Anyway thx for your help.
