1 - 5 of 5 Posts
So I've got a bit of a problem. I've got an Antec Fusion Remote Max case and an OCZ 600W power supply with a Gigabyte LGA775 motherboard that I just built. I hooked everything up, gave it power and... nada. I have power to the LCD screen on the front of my case, but nothing else. The hard drives don't spin, the fans on the case/processor/video card don't blow, etc etc. Just the LCD screen lights up.
Here are the exact components in question:
Antec Fusion Remote Max Case
GIGABYTE GA-EP45-UD3P LGA 775 Intel P45 ATX Intel Motherboard
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC
...I've consulted the literature that came with the case (virtually nonexistant by the way) as well as a pdf I found online without luck. Also looked at the mobo's user guide pretty carefully and could not figure out where I went wrong. Does anyone have any suggestions for specific things to be checking? I know all the pins I connected are snug... I assume I'm just missing something small and would like to hear if anyone has any ideas.
Thanks in advance,
Steve
Did you mount the MB on stand offs?
1 - 5 of 5 Posts
