I posted this message in the rear projection forum for starters however seeing as this problem has spilled over to all the televisions within the household (LCD Flat Panel, Direct View CRT, and Rear Projection dispalys) I figured I'd stick it here and see if anyone else had any input.
In the RPTV forum someone suggested having my power company come and check out the situation. I scheduled an appointment but unfortunately the window for such appointment spans more than a week. So if anyone else has any other suggestions, be they off the wall, a band aid apporach, etc... I could really use the insight as this problem is driving me up the wall
For some reason I just started having this problem a week or so ago and it appears to be a problem all over my house and with every television (Rear Projection, LCD, and Direct View CRT). Every so often when watching television or DVDs the picture suddenly gets darker or lighter.
Nothing has changed in my setup since the start of this problem so I'm really at a loss as to what could be causing it. I've seen a couple others report similar problems and having problems with their cabling or chaining devices together (Google resulted in finding a user with a similar problem who had his DVD player running through his VCR ) However in my case I'm using high quality cabling with digital or component connections making up 99% of my setup.
On top of that I've also noticed something else extremely strange that's been going on for a few months now. For one reason or other I'm getting little white or black artifacts on a large number of DVDs.
For a while it seemed to only occur in DVDs that were a year or so old but most recently I've noticed this problem in titles such as The Manchurian Candidate (this was actually one of the worst cases when it came to artifacts) and Saw. However other new releases such as Alien vs. Predator, The Village, Catwoman, Ray, Shaun of the Dead etc... etc... look absolutely stunning without a single artifact ever surfacing.
I've tested with a Denon 1910 (DVI Connection), Samsung 841 (DVI Connection), and numerous lower quality units from Sony, Panasonic, etc... and I've found that any movies that have artifacts when played in a given player will have those same artifacts in the same exact locations in any other player regardless of quality or connection type.
Now when I've sought help before, for lack of a better guess, it's been suggested that it's the discs but that simply can't be the case. I mean I've had this problem with dozens of disc, all purchased brand new and from a number of different retailers.
I've spoken with a number of the manufacturers of the various components but I've gotten no where. I talked to a number of local home theater experts however I was told by a number of them that they had never heard of such a problem and had zero suggestions, thus I'd say "expert" really isn't an appropriate description
The problem with artifacts however is not limited to DVDs as I've noticed this problem when watching a number of movies, even some in High Definition, on television. Oddly enough though the problem never crops us when watching standard television shows.
I'm grateful for any and all suggestions. Thanks
