Status
Not open for further replies.
1 - 3 of 3 Posts
I am very confused.
My setup
NEC plasma 42mp3 screen
Pioneer 737 Modded DVD player
Denon 3801 Reciever
I have plugged the Pioneer into the Screen via component leads.
however when i try to watch a pal disc it displays a very chopped up/squished image. I pop video ess. in and it works
fine - it is a ntsc disc.
I have played with all the settings etc but no luck!!!!!!
all discs are R4
and play pack is fine over s-video using every disc.
any suggestions????????
I'm not so sure that PAL will be displayed properly over the component outputs (as you discovered) I think PAL can only be displayed over the s-video, composite and scart outputs. I may be wrong but I seem to recall seeing a scart -> compnent coverter somewhere. I will check around and let you know.
This may be what you are looking for....and it is in Australia to boot!
http://www.dvdshop.com.au/accessories.html
Look for the scart to component video cable. Give them a call to be sure, but this may do the trick.
1 - 3 of 3 Posts
Status
