Problems with DVI 2x1 Switch
258 Views 0 Replies 1 Participant Last post by  fontabg
I purchased a DVI 2x1 switch from DVI Gear http://www2.dvigear.com/dvi2x1switcher.html . Connected on the input side is my HTPC & my Bell ExpressVu 9200 Sat Receiver which is the Dish Network 942, outputting to my projector. When ever I switch away from my 9200 to the HTPC and back again nothing is displayed except a small window at the bottom of the screen "DVI-Searching". The only way I have found to restore the signal is to go into the setup screen of the 9200 & change the HD settings from 720p to 1080i then back again to 720p and that seems to allow it to do a handshake again with the PJ and I get a picture. I have tried switching the inputs ports my two sources plug into on the switch but that does not make a difference. Switching does not affect the HTPC, it reacquires signal as soon as I switch back. Powering off the 9200 or the PJ does not cause the problem it is only when I switch the DVI switcher the problem shows up. Since the HTPC switches fine no matter which of the two inputs it is plugged into I am not sure if the problem is with the 9200 or the DVI switcher.
Anyone out there with similar issues and possible solutions?
Thanks in advance and Merry Christmas everyone!
Status
Not open for further replies.
1 - 1 of 1 Posts
1 - 1 of 1 Posts
Status
