1 - 3 of 3 Posts
Not sure if this should go here or with the HTPC posts but i'll give it a go here.
I'm having video/audio sync problems with my Hauppauge HD-PVR. I have the newest drivers just downloaded off their web site and that did not help. The first 2/3 of the program sometimes are fine, then it goes to commercial and the sync is off by as much a 2 sec. Some shows are just fine the whole way and some are off sync from the start.
I am recording to a USB HDD connected to the HTPC and then editing with VideoReDo V4 on a Pen Quad core on my main system with plenty of horsepower.
I know this has been an ongoing issue with this device. Has anyone figured it out and solved the problem, appears Hauppauge has not.
I see the same A/V sync issues with my Hauppauge PVR. I'm not aware of a fix.
Some people see this issue more regularly than others.
1 - 3 of 3 Posts
