Status
Not open for further replies.
1 - 4 of 4 Posts
About a month or so ago in the middle of watching smallville I lost reception
on channel 5 with my relatively new Sony HD200. Since then I haven't been able to get reception except for an occasional brief shimmer or two. When I use the channel up/down on the remote the channel doesn't even show up any more? I can still manually get to the ch of course. I've noticed that I no longer get 9.1,18.1,18.2 either which I got fine without ever a problem the first few weeks I had the HD200. Before that I was getting these channels just fine with a Samsung T-150 that unfortunately I no longer have to test with. Has any one in the LA area experienced similiar outages or has my box just gone wacko on me perhaps?
Thanks All For Your Help!
-Rand
Discussion Starter · #2 ·
Well I'm still stumped on this one. No amount of antenna adjustment will allow me to pick up Channel 5.1, 18.1, or 18.2. I used to get all of these channels just fine. Perhaps they changed something in the way they are broadcasting the signal? Is no one else noticing this in LA?
Rand
Discussion Starter · #4 ·
Thanks for checking Rick,
I just tried and for 5.1 I get no signal at all.
For 18.1 and 18.2 I get a "bad" signal according
to my HD200 and no picture shows up. I got
these channels fine for well over a month with the
HD200 and before that with a T-150 so I can't figure
out why those and only those channels would have
disappeared. No amount of moving the antenna seems
to make a difference at all. All of the other OTA signals
show up as strong on my HD200...
Rand
1 - 4 of 4 Posts
Status
