I recently purchased a Harmon/Kardon AVR525 and, overall, I really like. I immediately noticed an improvement in sound quality over my Denon 1803.
I have, however, noticed a couple things that concern me a little. The semi-osd can bet turned on or off. I prefer to have it off so I switched it off. It apparently needs to be selected for each individual source selection so I've turned it off in each of the them as I use them. The problem is that it doesn't seem to be "sticking" on the DVD input. Evertime I use the DVD input it's there, I turn it off everytime, and yet it comes back the next time I use that source. Is it possible that I just did it differently on the other inputs ( though I don't recall doing so), and the way I did for the DVD input was incorrect?
I also seem to be having a sound problem when watching DVDs. The sound is fine, but I have noticed a couple times where the auido would "disappear" or become choppy after I would pause (or press stop just once) or do a slow search. If I turn off the receiver and turn it back on, or switch inputs and switch back seems to fix the problem.
Has anybody experienced these problems or something comparable or have any insights/suggestions that might be helpful for me?
Ace
Ace
