Try to make this quick-
I've had a Panny 42" EDTV for about 3 years and just bought a 50PX50 for my living room (and moved the 42 to the bedroom). Bottom line the PQ on the 50 is much worse than the 42! Color definition isn't nearly as strong primarily. (i.e. the colors aren't nearly as bright - and the light in the rooms is comparable I'm not comparing one with the shades down and they face the same direction etc.)
Now one thing that is different (and I'm not sure if this could be the culprit, but this is why I'm asking here) - I have the tilt on the 50" at 15 degrees down because of the room (whereas the tilt on my 42" is 5 degrees down) - Could that ruin the PQ?? Otherwise I have a lemon? Or are the 50's just that worse (in which case I will swap back to a 42)?
Thanks in advance for your thoughts!
