Status
Not open for further replies.
1 - 16 of 16 Posts
I recently posted on another thread about the quality of my plasma, I can notice the artifacts alot more, and notice sometimes when watching some hd channels that the image sort of bounces a little bit. So someone told me to post my settings on the cable box, and on the tv as well. so please anyone if I have something set wrong please let me know. plasma is 42 inch samsung model # spp4251
thanks
Adrian
Settings on grey comcast motorola box:
use settings
tv type:16:9
ypbpr output: 1080i
4:3 override: 480i
closed caption : disabled
service selection:
analog: cc1
DIgital: no service
font size: auto
font style: auto
font color: auto
font opacity auto
font edge color and type: auto
background color and opacity: auto
settings" auto
tv settings
source list: component 1
picture settings
dynamic
color tone : normal
size 16:9
dnle: on
my color control:> easy control> custom
detail control:50 pink 50 green 50 blue
setup:
language : english duh
digital nr: on
miscellaneous > melody on
if anyone can help me with the picture that would be great, I jsut want it to look clearer
I'll bet you 10 to 1 it's your signal source.
Discussion Starter · #3 ·
What does that mean check to see if the wires are secure
Discussion Starter · #4 ·
Anyone with any helpful info
Discussion Starter · #6 ·
no it does not do that when I play dvd's, I was saying in the other thread that it looks better when I watch dvd's on the tv then watching hd channels.
Discussion Starter · #7 ·
oh I am in a apartment and they only have a comcast, so I dont know what else I can do.
Discussion Starter · #8 ·
Moderator
Does the Samsung have an orbiter option that shifts the image a few pixels to help prevent burn in?
Discussion Starter · #10 ·
no it does not have that option I dont think, checked the manual didnt say anything
Check how old the cable is to the apt. Even on STD cable, if the cable is old or weak, the signal will be bad. If the cable is old or brittle, the cable company should replace it at no charge.
Sorry to leave you high and dry....I was traveling..... go to Radio Shack and pick up an RF amp. They are relatively inexpensive. Try putting it in line before the input to the cable box. It can do wonders to boost the signal.
you can notice the artifacts alot more because you have a higher resolution tv set now and plus the tv is a decent size set. there is nothing you can do about that to clean the picture up. the only think i can recommend to help clean up the picture is get a good line conditioner. as far as the "bouncing" in the hd cable signal. i dont think there will be any fixing that unless you get directv. cable is garbage. sorry for the bad news but someone had to break it to you.
actually one more thing, make sure the sharpness on the plasma set isn't up all the way. people have the idea that the higher the sharpness the better the picture. if the sharpness is set to high it will create distortion. try putting it up at a maximum of 25% of the way.
Discussion Starter · #16 ·
wow thanks guys thats what I am looking for all those great replies. Ok I will try the rf amp for sure, I was also told that using comcast wasnt good and that I should expect all of this stuff happening. Hey joconj what is a line conditioner. I wonder how much that would help! I will also be sure to check the sharpness to make sure it is not high. If there is anything else please be sure to let a noob know.
Adrian
1 - 16 of 16 Posts
Status
