Sorry if this issue has already been addressed, but I can not seem to find a specific answer.
I have recently purchased the RCA257 up-converting DVD player from Walmart, and using the supplied hdmi cable and a monster hdmi to dvi adapter, have the player connected to a Hitachi 50v500 lcd rear projection tv.
My problem is that no matter what the resolution is set to (420p, 720p, or 1080i) the DVD plays for maybe a second and then there is a bunch of colored snow, ( if that makes sense). As soon as I pull out the hdmi cable from the DVD player and plug it back in, it works fine. But as soon as I try to put a new DVD in (without turning anything off or changing anything on the tv) it does the same exact same thing until the HDMI cable is pulled out of the DVD player and pushed back in.
My question is, could this be because of the fact I am using an hdmi cable with an adapter for dvi, or is it something with not getting a proper "handshake". According to Hitachi the tv is HDCP compliant, and I have gone through turning off the tv while the DVD player is on, and turning off and back on the DVD player after the tv is on, with no luck.
Any input would be appreciated, thanks.
