1 - 1 of 1 Posts
· Registered
Has anyone else seen this problem - Sony KDL52XBR4 - the right side of the screen is slow, ghostly and the entire picture is dim. The slow, ghostly problem is as if the right 1/3 of the screen is slow to update. A picture will appear to be in slow motion as it fades away and is updated with the new display. The dim is across the entire display. I can sometimes correct the problem by resetting the tv and then running it in "vivid" picture mode with the highest brightness. It seems as if something warms up after awhile and the picture will start flickering and then become normal. A service tech told me I need a new lcd panel. The TV is only 19 months old.
1 - 1 of 1 Posts
