Status
Not open for further replies.
1 - 6 of 6 Posts
The Kenwood 5900M claims to support VCD, but I have made several attempts to burn a VCD on my PC and play it with the 5900 with no luck. I am using TMPGEnc to encode the video file to MPEG-1 format and Roxio EZ CD Creator 5's "VCD Creator" to record the disc. I have tried both 650MB and 700MB CDR media. Has anyone had any luck in burning a VCD and playing it on the 5900? Any help would be appreciated!! Thanks,
Webb
Doesn't the 5900M only decode MPEGII?
Funny you should mention -- I just tried playing my Star Wars Trilogy VCD's last weekend and they would not play. I'd get the FBI Warning and then it would just stop; they played fine on my old DVD player.
H
I have a problem with VCD's on my 5700. 95% of them will play, but they all have green bars on the top and bottom of the screen. The bars pixelate..and they come and go. The VCD's were burned using CDRWIN and Nero. They play fine on my PC, and on other DVD players.
Any suggestions?
Udell
1 - 6 of 6 Posts
Status
