I am experiencing several problems with WD7UY and was wondering if anyone has noticed the same thing. There is always a risk when being the first to buy a newly released model that there are some problems. I'm wondering if anyone else is seeing similar problems.
1) There is a fog / gradation effect in many scenes. Mostly with the dark colors. Example, sometimes black hair has some green or purlple squares in it. As some scenes fade in or out, it has the 'topo map' look.
2) With a solid blue or green screen, I see faint 1 inch vertical bands which are made up of 3 thin bands each. The stripes are across most of the screen, but the last 1/4 edge of each side of the screen is stripe free. These aren't really noticeable unless I have a solid blue or green screen. You can't see them on a solid grey or black screen.
3) I see banding when there is a high contrast between a dark and light object on the screen. It is pretty obvious with ending titles on the screen. You can see dark bands next to the white text. I see this problem on my DTiVo to a certain extend, but also with a DVD signal. I think the DVD blacks are truer blacks, so the banding is not as obvious because there is no more darkening that can occur in the true black.
4) The most obvious sign that this is a plama problem is that there is noise coming in from the bottom of the screen depending on how bright the scene is. I was using 'Pirates of the Carribean' as the test DVD. I also tried hooking up a portable DVD with a RCA connector and still saw this noise. It's a faint brightness that pops up from the bottom (and sometimes down from the top) of the screen into the black bars of the letterbox. It is also very staticy looking.
Does anyone know what these problems are "technically" called so I can call VA tech support and explain them?
I'm interested if other WD7UY owners are seeing the same thing. Does anyone have a Pirates of the Carribean DVD they can try out to see if they see the noise in the letter box bars? This definitely does not seem normal. Hopefully it's not a flaw in all of the first batch of the WD7UYs.
