1 - 5 of 5 Posts
I bought my toshiba XA1 this past Dec new. I've only watched one movie with it where it did not skip or freeze up. I downloaded the 2.0 disk already, it plays standard dvd's fine, but with HD dvd's I seem to have problems with them. The hd dvd's look fine when I get them and I even clean them, the last movie I tryed to watch, it had no color. Am I just getting bad HD dvd's in the mail or do you think my player is bad. It played Batman Begins great, but two other ones froze or the color was gone.
Premium Member
You might want to check your cables and display. How do you have it hooked up? What display are you using?
What display is this connected to? Is it DVI to HDMI? Do you have any other HDMI 1080i sources to try that cable with?
1 - 5 of 5 Posts
