1 - 4 of 4 Posts
· Registered
Dear audio/digital content gurus:
I'm wondering if there is a product similar to Sonos that will allow me to send music from Napster to 3 different rooms/zones.
I like Sonos, but it is expensive and I don't need the wireless capability. I just want to be able to play different songs from Napster in 3 different rooms at the same time.
If there's a way to do this by integrating a couple of products together, I'm open to that too.
· Registered
Logitech Squeezebox.
It's a less expensive solution, but seems to be MUCH more finicky about proper setup. If you're technically savvy or comfortable with potentially a lot of tweaking/installing/rinsing/repeating then it is a good option - otherwise Sonos is the best choice right now.
· Registered
Discussion Starter · #3 ·
But the Logitech Duet system doesn't amplify the audio, does it? It looks similar to the Sonos Zoneplayer 90. Is there anything similar to the Zoneplayer 120?
I have in-ceiling speakers in place... Would I need a 3-zone amp/receiver or 3 different stereo receivers to have independant control?
· Registered
Sonos is the only option that isn't more expensive (Crestron/Niles etc...) I know of short of you adding the amplification with a squeezebox or similar as you mentioned.
I will say that yes the sonos is expensive but it works FANTASTIC!!! I use 2 ZP90's (Home Theater/Mbedroom) and 1 ZP120 powering in wall speakers in my office. It's the coolest thing I've bought in 34yrs in the A/V hobby and worth every penny for me. All of my music at full CD quality in the palm of my hand or from a PC/Laptop anytime anywhere in the house.
1 - 4 of 4 Posts
