Status
Not open for further replies.
1 - 4 of 4 Posts
Premium Member
hi,
from what I understand, if i'm using an NRS with a sharp 9000, I should pass it an interlaced signal as opposed to progressive. is this correct? what does an NRS do with a progressive signal?
if my above assumption is correct, do I not have to worry too much about the quality of the DVD player? I want a changer and was leaning toward the Kenwood Sovereign 5700 (5 discs)...but with the NRS would a lower priced Sony or other brand be fine?
thanks in advance,
tony
Tony-
I am using the same setup and faced the same issue.
The NRS will not accept a progressive input through the component jacks. It must be interlaced.
However, I would definitely say that the quality of the DVD player is important. You want a high quality interlaced player instead of having a requirement for a progressive output.
I really did not find a high quality "interlace only" dvd player, so I ended up with a DVD player that is switchable between interlaced and progressive. Your budget and personal opinion will have to determine what player to go with.
Premium Member
Discussion Starter · #3 ·
Thanks...given the above, what good changers exist? I know the Denon is good but has the chroma bug...the kenwood should be decent too - do these allow switchable progressive/interlaced on the component input? is that a pretty standard feature? any other changers to consider?
thanks,
tony
I'll second that. I think a high-quality interlaced player with component outputs (Sony 7700?) is the thing to feed the NRS.
1 - 4 of 4 Posts
Status
