1 - 2 of 2 Posts
Tried the step function and at best I've been able to find a code that will do everything I need, but as soon as I hit select to enter it in, the volume controls no longer work for the receiver. Tried volume locking the control to that setting and all, and still, no luck. It works fine while programming the remote (except for volume down I think, does nothing) but not after finishing up.
What gives? Does this remote just not work with this receiver?
The volume keys won't work at all without a tv code programmed to the tv device. Once there is a tv code, your tv code or ANY tv code, its volume is now in the way, but that can be remedied:
So with tv in, partial working Onkyo code programmed in, to get the volume and punch it through to ALL devices:
1. av1 or av2
2. press and hold MUTE & SELECT, wait for two blinks, release
3. enter 9 9 3
4. press SELECT
1 - 2 of 2 Posts
