Status
Not open for further replies.
1 - 1 of 1 Posts
Looking for some help with a technical query...
I have a Panasonic TH-50PHW5 plasma panel fitted with Tuner Terminal Board (TY-42TM5H) and Receiver (TU-PT600B).
I know the Receiver can utilise progressive YPbPr video signals via AV4C, I have an Arcam FMJ DV27 DVD Player running off this connection which is correctly displaying both NTSC and PAL progressive video.
My question is, I have second progressive source but RGB; which can either sync on Green or Composite or even be RGBHV.
I know that the screen supports this if you have RCA Terminal Board (TY-42TM4ZB), but does the Receiver support progressive RGB? And if so, how can I connect this progressive RGB source to the Receiver? I’d like to know which pins on which AV sockets I should use.
Anyone know about this? Tried it? Your input would be gratefully received.
StooMonster
1 - 1 of 1 Posts
Status
