When I run my Toshiba SD-3750 Progressive scan DVD player into the component inputs of my Sony KV-34xbr800 here's the deal.
Normal Play-Progressive: Some scan-line artifacts in some moving objects
Normal Play-Interlaced: Looks fine....
Slo-Mo-Progressive: Worse scan-line artifacts
Slo-mo-Interlaced: The WORST scan-line artifacts
To me.... I call SCAN-LINE ARTIFACTS those black or missing lines on every-other line on an object that is moving. Progressive scan was made to avoid this.
It happens on IN-GAME MPEG VIDEOS when a 480p game is running on my XBOX. When I disable 480p in the control panel of the XBOX, no scan-lines! The normal DVD player mode of the XBOX is not progressive, but is when a game running in 480p wants to stream video in the game.
I never had this problem on my RCA 38-inch HDTV. Anybody else have this problem?!?!? My progressive scan DVD worked silky smooth on my RCA! When you put it in slo-mo, there was never scan-lines like there is on this set. What gives?!? My tech. is going to look at it in a couple weeks when he comes to fix that line-sweep problem we've been having. Just wanted to see if anybody with the 34xbr800 has seen this with their progressive DVD players. ---- GS kid
