I am searching for a high quality DVD player that has the following attributes:
o Progressive Scan Video (preferrably with either Silicon Image or Sage components)
o First rate CD player
o DVD-Audio
In my search I have found the following DVD players (I haven't been able to get lots of info or reviews on all of them):
Integra Research RDV-1
Marantz DV-12S1
Enlightened Audio Ultra
Also, I found the following players that are probably a notch or two below the ones listed above:
Toshiba SD9200
Panasonic RP91
Kenwood DV-5700 (I am not that interested in a carousel)
I know there must be others that I should consider. Also, price is of some concern, but I also have found in the past that you get what you pay for. I have owned and/or demoed several different progressive scan players and I definitely can see a difference in the picture quality.
I would appreciate comments on any of the above players or suggestions of others that I should consider.
Jeff
o DVD-Audio
Marantz DV-12S1
Toshiba SD9200
Panasonic RP91
Jeff
