Not sure. I'm not a CAD guy, so I went snooping around on UPWORK and put out a proposal for the old quad-12 JBL project back in the day, found a cool dude in Montana that does my CAD work for a reasonable fee. Smart guy, I've set it up such that project progress is being done both informally via email exchange of information as well as in sequenced reports. This is probably the third project I've used him for, and by far the biggest in that many aspects of this design were unknown when we started. I don't mean box volume, I mean how we'd make that volume and what footprint/shape it'd be.
This is primarily due to wanting to make this "pretty". In the past it was always simple; make the box, double layer the front/recess the driver, add a couple dados and build the damned thing. Duratex and you're done. This is different where I'm pushing limits on how much curvature I can get, and fit the the drivers with no interference, and have my clamp mechanism not hit the walls. The audio part of the design (drivers, PR's, mass/tuning and box volume) were the easiest part of the design. It is due to the unknows that I had to take an analytical approach and actually see what could be done curvature wise -and at what expense. As such, I have run this project like an engineering project, weekly check ins, reports, milestones, etc, but fun since I'm the one in charge and not the corporate pressure cooker wonks I'm more familiar with. Photos of hand sketches, MS Paint being abused to mark up nice drawings, it's been fun running it like this, plus I have the "thought process" well documented for the analytical approach used for stuff that bends limits a bit. For example, have front facing drivers and want some side firing ones too? How close can you make them? Easy to think about, and if we're just fooling around it's easy to eyeball them, but really how would you figure it out if you had to make it VERY close?
Well, like this (partly):
Of course I added complexity by staggering vertical location, and actually making a model of the PR, but you get the point.
I could have built this sucker months ago, but I'm having fun seeing what flexing some engineering looks like when the final project is completed vs. slapping a box together. Will it be worth the effort and expense compared to a flat pack built in an evening? I guess we'll find out.
Bracing is about 60% done, little kiss here and there and volume reduce, then we'll do detail work; label plate, terminals, dowel pins for locating purposes (maybe), feet, etc.
