Status
Not open for further replies.
1 - 2 of 2 Posts
I'm just starting constuction on my HT. What a great site!
Question: I've wired the equipment rack, projector, active front/center speakers, 2 subs on the same 20a circuit. Have the stewart screen wired on separate circuit. Now I think I should do the same with the projector. Do you think it'll be a problem with interference if I leave the projector on the same circuit? Thanks.
For quite sometime, I had everything in my theater on a single 15amp circuit. Sub, amp, A/V equipment, projector, etc. I never had a problem with blowing a circuit.
I did finally add an additional 15 amp circuit because "more is better". Now I've split my equipment about evenly between the two circuits.
If you do opt for more than one circuit, make sure that both of them are on the same leg (or phase) of the main panel. This should help to avoid any potential ground loop hum problems.
1 - 2 of 2 Posts
Status
