You can use SMART III to do this (it comes D65 calaibrated by having it put against a D65 light source and the values of what Steve measures, you then put it into the spreadsheet). The meter that is shipped with the package read light levels all the way down the IRE ranges. Also Colorfacts with its light meter uses the USB port and by using its software, it automatically gives out the readings without having to input data manually. As with SMART III, its more time consuming as you have to actually place either the RED, GREEN or BLUE filter on the meter to get measurements for the different colour and takes a little longer to do and you have to manually input the readings from the light meter into the spreadsheet on the pc.
Yes, once you install a filter, you will then have top adjust as you are now putting a filter on the lens to compensate for that limiting colour. So when you take a new measurement, you will then have to adjust RGB levels to get the colour balance back to D65.
You can simply adjust the RGB levels to obtain the best contrast but with a filter you can obtain and even higher figure. You can without a filter try and get the max on/off contrast buit that will then make your colour balance off the intended mark your after for D65. A filter compensates for the limiting colour.
You can max contrast by using different modes like the one you stated but you will be again, like i said, missing the aim of trying to get closest to D65 reference. The whole point is trying to increase contrast while keeping it at D65 like Cine4Home is doing. You will have toi change the gamma response for that particular colour by adjusting thr gammar of that colour. Maybe you wont be able to do that using the projectors adjustments but programs like powerstrip can do that for you using a PC.
All Cine4Home is doing is using the proffessional Colorfacts light meter and software to test the projectors and by using filters they are obtaining higher contrasts with them while keeping the optimum colour balance throughout the IRE ranges.
