1 - 4 of 4 Posts
We watch movies outside a few times each summer (maybe 4-6 times/year).
I currently unhook my Panasonic projector from my celing mount in the HT; but that is becoming a hassle.
Would appreciate any recommendations for a projector to use a few times/year. Looking to keep cost low as possible.
Any ideas?
Thank you
Mike
assuming you won't be needing absolute blacks, and would prefer something bright, you might just watch the classifieds for a used projector. even one with a few hours on the bulb wouldn't be a deal breaker for occasional use.
i just upgraded my 720p epson hc720 to a jvc x35 and my plan is to keep the epson around for this exact reason. i'd like to give the outdoor thing a try, but i don't want the hassle of moving the jvc around.
my upgrade actually started because i was wondering about buying a cheap data projector to use outside, and figured my money was better spent buying a better one for the basement, than a crappier one for the backyard, haha. if you've already got a good one, then buying something cheap used seems the most logical to me.
I'm planing on doing the same thing as you. I just grabbed an Epson powerlite home cinema 705HD refurbished directly from them. Not sure about posting pricing but safe to say it was cheap enough where I don't mind taking a chance with it. I'll probably use it in my basement as well in the meantime while I figure out what is wrong with my Marantz vp4100. Can't wait to get it and try it out.
1 - 4 of 4 Posts
