I posted last week about deciding between a plasma and projector to replace my old non-HD (or even ED) RPTV. I have room enough for somewhere between an 85-92" screen depending on if I go with 16:9 or 2.35:1. From looking at projectors dimensions and clearance, it looks like I'll have between 8.5 and 9' between the front of the lens and the screen. I'll most likely be using this for outdoor movies a few time a year, so brightness would be good. The room is also not going to be painted black, as it's also a den. I'm not opposed to painting it darker, though. It will be fairly dark, and is can be totally light controlled - no windows. I'll probably mount a shelf on the back wall for the projector; it'll also be over my head (couch is against the back wall).
I'm considering an Epson 705HD. I know this projector is said to be bright, but will this be a problem in a room with some reflection? Price, both of the projector and of bulbs, is a major consideration. I've been looking at some used projectors locally in the $175-200 range, but all are 480p. I think I'd want better than that, plus, with unknown bulb life, I think I'd be better off with a new one with a new bulb and warranty. Are there other models I should be looking at for this application?
