1 - 1 of 1 Posts
Ok I've been doing some reading but thought I should try to get some input, any help is appreciated!
My buddy is doing a projector set up in his game room, it can be light controlled well but will be used for watching sports in addition to movies.
Screen will be on a wall 14' wide and 8' tall (then an angle, ceiling is at 9'), seating will be about 19' back from the wall so thinking of a fairly big screen probably 130".
Projector will be ceiling mounted and distance is not an issue, it can be mounted any distance from the wall.
Looking to spend 1000-1500 max on the projector. I'm going to encourage him to check some out but wanted a little direction. Thanks!
In summary:
130" screen
Ceiling mount, any distance back, 1' higher max from top of screen
semi-light controlled room
seating 19' back from screen
$1500 max budget
1 - 1 of 1 Posts
