I am thinking of ceiling mounting a projector but the best spot is abuot 4" from an exposed hot water pipe. The room itself is pretty cold but the pipe puts out a decent bit of heat in the winter (it's part of the heating system for the house so it is cold other times of the year).
The pipe is very warm to the touch, but not so hot that it would burn you or that you couldn't hold onto it for a while.
Will placing the projector this close to the pipe cause overheating issues? Would simply putting some foam insulating wrap on the pipe be sufficient to reduce any concern?
