Status
Not open for further replies.
1 - 4 of 4 Posts
I'm putting together a HT which will not allow the projector to be mouted overhead from ceiling. That's the only way I've done them in the past. I've seen lit which showed a projector placed in cabinet between a row of 4 theater chairs.
Has anyone done this or can you point me in the right direction? Phil
I have seen CRTs mounted this way and they are much bigger than a Digital pj.
If you are backing it up to a riser, make it a hush box as well with its own ventilation, sound deadening etc... Put some optically clear glass and your set. run a duct to a remote mounted fan to suck air through it to keep the temps in there at ambient. If it backs up to a riser you could run the duct through there and outside the room to vent the heat.
Should be a killer setup with a high power screen if you need the brightness.
Good luck.
Excluding line of projection to the screen and line of foot to the projector I know of no other problem with your plan. My first theater used a crt projector mounted on the floor. If you are starting from scratch and have access to the flooring you can run necessary wiring and, perhaps ducting. A hot stream of air from a digital projector is uncomfortable on one's knees, so that is an area of concern... Art
1 - 4 of 4 Posts
Status
