Hi all. I would appreciate any advice on ridding my projection setup (Runco 991, NRS, Canare cable about 35' long) of the problem in the attached photo. I am not sure of the correct terminology but it looks like an echo of vertical lines. Horizontal lines are not effected. The pic is from the Avia sharpness test pattern. I tried an 8' length of Canare cable and it made no difference. I tried both component and Svideo inputs to the NRS and it made no difference. I tried changing the NRS to high and low sync output rates and this made no difference. Any ideas?? Thanks for your help. Jeff
