Projector problem?
217 Views 1 Reply 2 Participants Last post by  Gary Lightfoot
Hi all i have a problem with either my projector or my samsumg receiver. Heres my problem i am only getting audio no picture. I am using component cables and there hookup fine and i have tested the cable wire with another sat box and it works fine. The samsung i wanna use is a new box and i have had it working before so i cant understand the problem. Do you think it would be some type of setting? I have the Hitchai pj-tx100 projector and my dvd player is working fine and i have my computer working fine so i dont know what to do. Thanks for any advice!
Status
Not open for further replies.
1 - 2 of 2 Posts
It's possible that you may have the output switched to something else - I have a DVD player that can't send all signals through all outputs, so you have to select the one you want. If you get it wrong and don't have other outputs connected, you may not get a picture on the component cables anymore. You then have to switch to the other output to see it. For instance, setting it to s-video might dissable the component outputs, so you now need to connect the s-video output to the pj to see the output to change it back.
Can your pj take both interlaced and progressive inputs? Maybe it's on one that the pj cannot display. Or perhaps you can put out different RGB signals and somehow the wrong signal is being sent and the pj is not deisgned for it.
I'm guessing of course, but you never know, one of them might be right. :)
Good luck.
Gary.
See less See more
1 - 2 of 2 Posts
Status
