Hi guys
I'm considering a new projector for my HT room. I intend to have a 16:9 screen of size around 90-110", and I want to ceiling mount my projector. My HT room is currently under renovation, and they need to know where the projector will be, so I have to know the distance from my screen.
The problem is, I don't know which projector I'm gonna get. It'd be good if the projector has some sort of zoom, so that it doesn't matter if my distance isn't that accurate, but I'm also considering the NEC LT150, which doesn't have any zoom at all, so I have to know the exact location. projectorcentral.com only has throw distance calculations for a 4:3 screen, so I'm wondering how I can calculate my throw distance for a 16:9 screen.
Some of my projector choices are the NEC LT150/155, VT540, Sanyo PLV-60 and Sony PLC-VW10HT or 11HT if its good.
Also, another problem I have will be ambient light, since my HT room will be on the top floor, with a few large windows on the walls and rooftops for sunlight to enter. Even with curtains, I foresee that the ambient light will be quite bright, so I'm wondering if the LT150, with its 800 lumens output, will suffice?
