1 - 2 of 2 Posts
· Registered
Hi,
I have an Epson PowerLite 730c that was working properly until recently.
It will no longer focus correctly. The focus knob will turn and change the focus, but it won't actually get to a crisp image.
It sort of ghosts the image... The ghost changes focus, but the actual image doesn't change. I'll try to get pics of this.
I also noticed that although the zoom knob turns smoothly, the zoom itself is not smooth, it jumps a minor amount. Not sure if that's related.
Any ideas? If I need to take it apart, what do I need to adjust?
· Registered
Probably not the issue but just something to consider...
Did you change the distance that you are trying to project from, you may be too close or too far if you cannot get it to focus.
Jason
1 - 2 of 2 Posts
