I have small room to work with. It's about 13 X 10, and that is being generous.
I was wondering if Projectors work well in small spaces such as this? The screen won't be very big, but it will be larger then any HDTV that doesn't cost $100,000. I am hoping around 100 inch's or whatever number around that I can purchase.
Is there a minimum distance to have a projector? Do I need a room bigger then this for it to work properly? Also, if I don't, can you recommend any inexpensive (in the 1000-1500 range) projectors for a first time user?
I have been very interested in getting a projector for a couple years now, and have wanted to build a HT for a long time (probably another few years before I have the time to gut and re-finish the basement). I figured I may as well jump in now, but wanted to ask a few questions before I dropped $1500 on a projector that may not even work right in the small room.
Thanks for any help.
