1 - 8 of 8 Posts
· Registered
Hi,
I am aiming for a flush ceiling installation of my PJ. On the Chief website it shows the RPAU's height as 44mm. It then says you need the supplied universal bracket to fit to the inverted projector. Does anyone know how much more this bracket adds to the height of the installation ?
The RPA-186 custom mount's total height is 44 + 19 mm= 63mm.
Thanks ,
Tausif.
· Registered
I don't know if I did it wrong the first time but I just mounted my chief directly to the ceiling. I recently went with an HP screen though and had to purchase a ceiling plate and an extension to lower the projector. Seemed to work fine as is before hand though.
1 - 8 of 8 Posts
